Chevy body on a dodge frame
Old 06-20-2017, 09:17 AM
BentWrench's Avatar
All done. I present to you a Chevram!
Attached Thumbnails Chevy body on a dodge frame-426efba9-049b-4b38-8c76-7edfd981c3d7.jpg
  #32
Old 07-09-2018, 12:11 AM
BentWrench's Avatar
Striking a pose on 40’’s
Doing what flat decks do best.
  #33
Old 08-30-2018, 10:09 AM
12vcanada's Avatar
Default Chevy on a cummins
Hey im considering doing this and have everything pretty well ready, my one question is didn't yiu put the whole hydroboost system from the dodge cab onto the chev cab? Or what's the other option of doing it
thank!
  #34
Old 08-30-2018, 11:19 AM
12vcanada's Avatar
What did you do for the hydrobooster? Did you make the dodge one work on the Chevy cab? Thanks
  #35
Old 09-05-2018, 08:40 AM
BentWrench's Avatar
Yes I used the Dodge Hydro and Clutch master , I had to modify the fire wall mount, as-well as build a clutch pedal assembly. Also delete the ABS pump with a 3 port Willwood proportioning valve.
  #36
Old 07-21-2020, 05:28 AM
areloads's Avatar
Default OBS Chevy ext. cab regular box on 2nd gen dodge single cab long box
I was wondering if anyone knew how well a 93 Chevy ext cab regular box Body would fit on a 2nd gen 12v dodge single cab long box chassis
  #37
Old 07-21-2020, 07:36 PM
BentWrench's Avatar
just minty, with a little bit of effort
  #38
Old 07-22-2020, 04:12 AM
areloads's Avatar
Do you think it would be easier to do the body swap or to just drop the 12v into the Chevy
Because I’ve heard that they sell a motor and trans mount conversion from the 5.7 to a 12v but I have no idea where I would find that kit
  #39
Old 07-22-2020, 09:59 AM
BentWrench's Avatar
the front end will be the biggest draw back dumping the Cummins in a chevy setup, IMO body swaps are the way to go because the drive line science is already done. Then Its just a matter of cab mounts and linkage with a bit of wiring and the brakes. Provided you or someone is a competent welder to safely make the cab perches.
  #40
Old 07-25-2020, 05:00 AM
areloads's Avatar
Well I’m proud to announce that the start of my Chummins has begun
Quick Reply: Chevy body on a dodge frame
