6.0 oil sending unit location
Old Jul 22, 2012 | 06:37 PM
Whitman41's Avatar
Default 6.0 oil sending unit location
Ok guys mt oil hand buried on me. Mechanic told me is was oil sending unit but by the time I got it to him it was working again so I took it home. It started dropping more often now when Rpm gets low. So I bought one at part store and have googled and youtubed til my fingers blead. Where is the oil sending unit located on my 2005 6.0? Help please I'm stumped? Also called oil pressure switch. That's what it's called in the 6.0 bible.
Old Jul 22, 2012 | 09:14 PM
bobfbigman's Avatar
it is located right next to your oil filter housing, more to the back side of it, there is also a oil temp sender right next to the oil supply tube for turbo.
Old Jul 22, 2012 | 11:00 PM
ntmdtr3fan's Avatar
I just replaced mine as it blew a hole in the top of it somehow. Its actually behind the oil filter close to and almost under the turbo. You gotta take off your air filter tubes to get to it. Sits on top of the motor. Let me find my pics and Ill post them if I can.
Old Jul 22, 2012 | 11:10 PM
ntmdtr3fan's Avatar
here is the pic. 6.0 oil sending unit location-oil-pressure-switch.jpg Youll see where it says Garrett on the turbo.
Old Jul 23, 2012 | 09:15 PM
Whitman41's Avatar
Do I disconnect the tube from the turbo also or just the one to air box
Old Jul 24, 2012 | 01:21 AM
ntmdtr3fan's Avatar
yeah. forgot that one. do both makes it a little easier to get to. unplug harness on top. I think it takes a 17mm socket. But not sure. make sure area around it is clean.
Just curious. Last name Whitman? Im a Whitman.
Old Jul 24, 2012 | 07:03 AM
Whitman41's Avatar
Middle name named after my great grandfather Whitman Williams
soco
Jul 27, 2015 06:06 PM
scubasteve12
Mar 29, 2015 09:39 PM
emilio2496
8
Jan 13, 2015 05:03 PM
ash23k
Dec 30, 2014 08:31 PM
iam1746regan
Dec 21, 2014 05:06 PM
