linkage
Old Jul 22, 2012 | 03:33 PM
codycatract's Avatar
Default linkage
im getting everything rounded up to do a cummins swap in my 97 crewcab, i want to run nv4500 with 1" 3/8s input shaft with 5th gear fix, and a manuel shift np271 t case behind it with the 29t input shaft to fit tranny. my question is shift 4x4 linakage, has anyone one here ran that before
Old Jul 22, 2012 | 06:12 PM
fordornothing's Avatar
well you will probably have to make something up yourself..
Old Jul 22, 2012 | 07:08 PM
cumminsf150's Avatar
does the truck have a t case shifter now?
Old Jul 22, 2012 | 09:11 PM
Yes the Manuel b.w. that's in it
Old Jul 23, 2012 | 07:14 AM
well my suggestion would be take the ford lever and and the dodge t case linkage and weld them together in the middle, i know a guy named MANUEL who did the same thing on his MANUAL linkage
Old Jul 23, 2012 | 12:36 PM
10-4 ill figure it out just was seeing some of the ways people might have done before thanks
Old Jul 24, 2012 | 09:17 PM
If you can weld the world is yours, theres not a problem you cant cut and weld your way out of.
pappyscrapster
Feb 18, 2015 09:44 AM
Lawrence D. Sanders Sr
Jan 23, 2015 12:47 PM
Jan 23, 2015 12:22 PM
jmerriman17
Nov 16, 2014 02:13 PM
marks86
Oct 23, 2014 03:25 PM
