6.0 problems
Old Jul 18, 2012 | 10:46 AM
jmdickenson's Avatar
Default 6.0 problems
i have a 2005 6.0 powerstroke all stock recently put in new ficm truck sometimes runs poorly revs up and loses power at times. anybody know what cause might be. serviced regularly only problem so far has been ficm but i am fearing the dreaded egr problem i have read about
Old Jul 18, 2012 | 10:53 AM
Mdub707's Avatar
Tell us more about the truck. How many miles? How is it used? Does it idle a lot? Does it tow anything, or is it a grocery getter.
Have you tried just simply pulling the EGR valve and cleaning it? Probably what it is if it's still there...
Old Jul 18, 2012 | 02:23 PM
it has 88000 miles on it it doesn't tow hardly at all. doesnt idle a lot mainly wifes truck so she doesn't drive it hard, the egr valve has never been pulled or cleaned, plan on doing that just from what i heard it needs cleaned. would it sticking open have an effect. im still learning bout diesels worked mainly on older gas engines
Old Jul 18, 2012 | 05:50 PM
Whitman41's Avatar
Have you checked your battery load that's always a good idea. That can cause the film to act up.
Old Jul 18, 2012 | 06:57 PM
Ficm is 1 month old. Batteries are 3 months old nothing extra on truck to draw voltage
Old Jul 19, 2012 | 07:55 AM
Mdub707's Avatar
New FICM's aren't any better than the old ones, they will all fail until repaired properly. Though, at 1 month old it's probably fine.
Clean the EGR, or better yet just delete the whole setup.
cjgregory
Mar 31, 2015 01:45 PM
scubasteve12
Mar 29, 2015 09:39 PM
TNTPrime
Jan 5, 2015 06:13 PM
mrfizz2012
Dec 11, 2014 10:38 PM
angies04
Sep 29, 2014 04:11 PM
