Truck dies going down road.
Old Jul 17, 2012 | 12:35 AM
GeArHeArT's Avatar
Default Truck dies going down road.
The truck is a 1995 PSD and the problem we are experiencing is the thing shuts of going down the road. Just as if someone shut the key off. If we run it at WOT, it's fine, but when you let off, it shuts off. It's fine when the truck is cool, but seems to be the worst when it's hot. No codes. If someone could help me trace this thing down, I would greatly appreciate it.
Old Jul 17, 2012 | 08:40 AM
twinboys's Avatar
This sounds like the cam position sensor.
Old Jul 20, 2012 | 10:57 AM
Haveastroke's Avatar
i had something similar when i bought mine. it was ipr valve orings. $30 from international, $15 napa.
Old Jul 20, 2012 | 11:55 AM
CSIPSD's Avatar
It sounds HPO related... Injectors or IPR.
How many miles?
Mods?
Old Jul 23, 2012 | 09:11 AM
Cratos's Avatar
check your oil pressure if it gets below 7-8 psi it will shut down the truck.( not enough psi to feed the HPOP.)
Old Jul 23, 2012 | 08:45 PM
GeArHeArT's Avatar
motor has 120,000 on it. i changed out the cam sensor and the IPR...still having a problem. its only once the truck has warmed up after about 15 minutes or so that it will shut off. then if you let it sit for a few minutes, it will fire back up and you're good to go until it gets warm again. Read somewhere that it could also be a bad IPC.
redjello
Apr 21, 2015 12:35 PM
1969olds
9
Apr 18, 2015 02:59 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Strokin in wisco
Jan 23, 2015 12:28 AM
Oct 14, 2014 08:40 AM
