94 6.5 turbo 2500 fuel issue
Old Jul 11, 2012 | 02:53 PM
Polar1112's Avatar
Default 94 6.5 turbo 2500 fuel issue
I've got a 94 6.5 chevy 2500, and it is frustrating the hell out of me. It died on me and started right back up, so I decided I should change the fuel filter. In doing that I found that the lift pump was not working. I replaced the OPS, and then the lift pump now they are working, but I'm still having the same problem. It will start and idle for about 15 minutes and then sound like it is not getting gas resulting in its death. Then it takes a few trys to get it going again if it starts at all. The next day it fires right up, and repeats this cycle. When trying to start it after it dies if I push down the gas it shakes like its still not getting fuel. When it does start it isn't blowing out any smoke or nothing just starts and you wouldn't even think there was a problem. Is there a pump on the gas tank, the guys at Shucks don't seem to think so, also they said it doesn't have any form of sock in the tank either. The fuel system just seems to lose pressure. It also isn't giving any codes. I'm at a loss and need help.
Old Jul 12, 2012 | 03:51 AM
97cummins's Avatar
if you put your question in the chevy you'll get a better responce,this is the introduce yourself section.
Old Jul 12, 2012 | 07:16 AM
RAW's Avatar
RAW
Come on buddy, directly above your post is this:
This will be moved to the correct section.
Cavnar
Sep 9, 2015 07:18 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
greatlakes diesel
Feb 13, 2015 09:55 PM
moneypitk5
Feb 12, 2015 11:01 AM
