turbo?
Old Jul 9, 2012 | 11:05 AM
helton87's Avatar
Default turbo?
I have a 03 Cummins HO with an edge ez tune, muffler delete, and cold air intake, all I’m wanting to do is upgrade the turbo but without having to add head studs. I will do that later but for now all I want to upgrade is the turbo, it’s a daily driver and I haul maybe once every 2 to 4 weeks. What are your recommendations?
Thanks!
Old Jul 9, 2012 | 12:24 PM
cummin_un_glued's Avatar
FormerVendor
With only an ez whats wrong with the stock charger?
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old Jul 9, 2012 | 01:40 PM
helton87's Avatar
Nothing is wrong with it i just want faster spool lower egt's and more power, ill be getting a smarty in a few weeks also
Old Jul 9, 2012 | 06:29 PM
FormerVendor
S362/65/.80 gated or S364/68/.80 gated i would go with the 64 if you ever plan to do any more upgrades like larger injectors
Old Jul 10, 2012 | 06:56 AM
helton87's Avatar
what brand of turbo would you recomend though? More than likely i will be getting larger injectors but it will be later on down the road. but thank you!
Old Jul 10, 2012 | 12:39 PM
FormerVendor
The s300 series are borg warner chargers. For the 362 a phat shaft 62 is the best deal. For the 364/68 we have them built for us by an authorized borg shop.
Old Jul 11, 2012 | 08:45 AM
helton87's Avatar
what do you think about the ATS Aurora 3000 turbo kit 202-930-2272? i have read alot of reviews and i havent really heard anything bad on them
nevermind, they dont have a wastegate, ill be going with the 64, do i have to use the stock exhaust turbo housing on it though, and what do you think, 12 or 14 turbine?
Old Jul 11, 2012 | 10:02 AM
FormerVendor
68 is the turbine wheel .80 is the 14cm turbine housing. Thats what i would use.
Old Jul 11, 2012 | 10:03 AM
helton87's Avatar
thank you!
Old Jul 11, 2012 | 12:20 PM
FormerVendor
No problem just let me know if i can set you up with one.
