LMM Performance Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines Related To Performance And Longevity
Looking for more power
Old Jun 30, 2012 | 12:44 AM
Dmax2008's Avatar
Default Looking for more power
So I recently installed a Air Dog 2 150gph lift pump and I'm loving it
However I've been needing more power for my towing applications. Any help would be appreciated!
Old Jun 30, 2012 | 09:30 AM
BriteWhiteRam's Avatar
just for towing? If money is not a big deal I would look into getting a pre-tuned ECM from duramaxtuner.com loaded with their transmission safe dsp5 tunes, they have a modified stock tune for better mileage, a light tow tune with turbo brake, a heavier tow tune with turbo brake, a performance tune, and a high performance tune
cheaper than buying EFI live
Old Jun 30, 2012 | 01:21 PM
Dmax2008's Avatar
Well mainly towing but its an occasional weekend warrior. I'd like to have the truck in the low 12s with my towing capacity still there.
Old Jun 30, 2012 | 06:04 PM
for that you're going to need a heavy tune(around 500hp) and a well built trans, but Duramax tuner has a few heavy tunes as well that can get you into the 12's but they run hot and will shorten the life of your engine
Old Jun 30, 2012 | 11:21 PM
Dmax2008's Avatar
Yeah that's the only problem. any other upgrades to the engine you would recommend?
Old Jul 1, 2012 | 09:26 AM
egr block plate and pcv re-route to keep the gooey soot out of your intake
gauges if you dont have them(pyro and boost)
the engine is pretty stout in stock form up to that 500hp range, then you have to start sinking money into pistons, and head studs, turbos, more fuel etc.
you can make lots of power with a duramax, just depends on how much you're willing to spend to get it there
but for now, if you just want a little more go for towing and spanking tough guys at the like i suggest getting a pre-tuned ECM from duramaxtuner.com, its what I run and on the hottest tune (415rwhp) it will put shame to quite a few other rigs on the road
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
