Best mods for pulling
Old Jun 29, 2012 | 02:03 PM
diesel life's Avatar
Default Best mods for pulling
Ok guys getting ready to buy a 1993 doge 350 dually extended cab long bed dually with the 5spd. Gonna use the truck to hook in the local work stock class, and street drive some. The truck is in great shape it's bone stock so I was wondering what would be the best mods to do to this truck for sled pulling???? Besides a p-pump conversion, that most likely will come in a year or so,most likely it will become a dedicated puller.. Never been around the 1st gens too much always had the vp44 trucks so any help is appreciated thanks guys
Josh
Old Jun 29, 2012 | 02:05 PM
biged681985's Avatar
3200 gsk sprig, a fuel pin and 5x.012 or 5x.014 injectors
Old Jun 29, 2012 | 07:49 PM
Sounds good will the turbo handle those or should I upgrade that as well??? The clutch will be getting a dual disk as well
Old Jun 29, 2012 | 10:31 PM
They don't make a DD for those if I'm not mistaken. And if you're pulling in work stock, depending on rules it has to be a stock turbo
Old Jun 30, 2012 | 10:01 AM
BIGREDGOAT's Avatar
Southbend and valair both make DD's that will work but be warned, its not if your input will break, its when ill it. I had mine cryoed and it has held, so far....
Sent from my G'zOne Commando
Old Jun 30, 2012 | 10:07 AM
BIGREDGOAT's Avatar
And with 5x14's the stock turbo will get damn warm, but then again I put a he351cw on mine and I can still bury the gauge, just not near as fast.
Old Jun 30, 2012 | 10:34 AM
In Indiana it just has to be a stock appearing turbo, according to the rules that I've read, I could be wrong, I know my cousin pulled work stock with an s300
Thanks I wasn't aware of the inPut shaft being that week, so we will adress that issue as well and a DD.....
Last edited by diesel life; Jun 30, 2012 at 10:34 AM. Reason: Automerged Doublepost
Old Jun 30, 2012 | 12:41 PM
BIGREDGOAT's Avatar
Yea im on my 3rd shaft, I twisted the first and it didn't break, then I snapped my 2nd one.
Old Jun 30, 2012 | 12:45 PM
cummin_un_glued's Avatar
FormerVendor
go ahead and swap in a nv4500 if you can. also alot can be done with the stock charger to make it pull right with the S300's and still be WS legal
Old Jun 30, 2012 | 01:31 PM
jdbigblue12v's Avatar
do a GDS 60mm upgrade from gillette diesel just replacing the exhaust housing, different comp. wheels and bigger compressor housing
