valve springs
Old Jun 26, 2012 | 01:44 AM
cincolatham11's Avatar
Default valve springs
So I've Ben searching around about valve springs and gsk . I cant seem to get good simple answers . So 1 . Whats the benefit of say 60lb valve springs on my 99? And 2 24v doesn't have governor springs does it. I think I read somewhere that its for ppump only.(please correct me if I'm wrong here I'm still learning)
Old Jun 26, 2012 | 07:14 AM
RAW's Avatar
RAW
1, you already have 60lb springs in a 24 valve. Going to 110 pound springs is the most common route. A stronger spring prevents the valve from opening under extreme boost levels. As boost pushes on the valve down, more effort (stronger spring) is required to keep the valve closed.
2, Correct, that is a mechanical, p-pump, system.
Old Jun 26, 2012 | 08:42 AM
Thanks and what would be the best place to get some 110s?
Old Jun 26, 2012 | 08:52 AM
RAW's Avatar
RAW
From our sponsors would be the best place. When you request a quote, they will send you a private message with what they can do for you.
What kind of boost are you seeing? Upgraded springs aren't required until 60+ PSI, or an upgraded Cam is installed.
Old Jun 26, 2012 | 05:51 PM
Well I'm just throwing around ideas I'm about back to stock now the quad I had was giving me problems. I'm only running about 22-26 psi but if I do hard parts instead of electronics I'm gonna do it all at once I'm just trying to get a good parts list together. But I'm thinking about a different chip too. What would yo recommend?
Old Jun 27, 2012 | 06:50 AM
RAW's Avatar
RAW
If your not looking for anything else but power, Edge Comp. If you want turbo timer, gauges, backdowns, alerts, and other features, Edge Juice with Attitude CS.
RA113024
Mar 13, 2016 07:42 PM
Jake12valve
May 10, 2015 11:57 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
POWERSTROKEMANIAC
Dec 30, 2014 11:32 AM
