turbo help......please
Old Jun 25, 2012 | 03:59 AM
chevy assassin's Avatar
Default turbo help......please
Just picked up a S300AG072 need to no specs and best injectors to run I don't pull heavy but if I do i dont want egr problems I will b running a smarty s03 and edge comp any advice is great
Egt not egr dang phones
Last edited by chevy assassin; Jun 25, 2012 at 03:59 AM. Reason: Automerged Doublepost
Old Jun 25, 2012 | 06:17 AM
RAW's Avatar
RAW
A very fast google search shows that turbo came on 330HP engines. hat is 100HP more then what these truck came equipped with. You should be safe with 100 to 150 HP injectors. With both fuel adders, the lift, and those big tires, towing may get hot regardless.
Old Jun 25, 2012 | 07:25 AM
It's geared to compensate for the tires it runs just like a stock truck would... With the things ive got done to it now I can run wot on an steep incline and barely touch 1000 pre turbo
Old Jun 25, 2012 | 08:30 AM
RAW's Avatar
RAW
That's with the S300, correct? I would still suggest 100 to 150 injectors. They are a nice all around good size.
Old Jun 25, 2012 | 04:11 PM
No im still runnin the stock turbo boosting about 32 psi
Old Jul 19, 2012 | 12:32 PM
lobsterman04's Avatar
I'm running that same turbo. It can get hot if the box is set to kill. And the are set to 25psi for the waste gate...other than that it is a noticeable improvement in performance and sound.
Old Jul 20, 2012 | 09:43 AM
These turbos can handle 45 psi all day safely I'm gonna take stock gate off how does it run with the box off and just the 150 sticks
Old Jul 24, 2012 | 11:14 AM
Temp is great with the box off and clears up quick! I am going to get a bigger wheel for it one day though. And I have mine set to 44psi.
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
