04 wont start
Old Jun 23, 2012 | 12:49 PM
jetmedic's Avatar
Default 04 wont start
04 wont start. no codes. no fuel at rail. lift pump replaced already. any help greatly appreciated. Gary
I cracked fuel line at rail and absolutely no fuel comes out. There should be some kind of pressure after cranking right?
Old Jun 23, 2012 | 05:12 PM
dmaxkiller's Avatar
you should have 5k psi of rail pressure to start. if u have no fuel to rail. u need to check the fca it could be seized up. maybe bad cp3. what happened when it quit? we need a lil more info.
Old Jun 23, 2012 | 05:49 PM
jetmedic's Avatar
I was in my driveway ready to go. It Started and then just quit no warning just quitNo codes. Truck wasn't hot I drove it earlier that day to work and it sat for a couple hours. Like I said I started it and then quit I didn't get a chance to Put it in gear to drive away.
Old Jun 24, 2012 | 03:36 PM
dmaxkiller's Avatar
sounds like the fca seized up to me. but i could be wrong. or your pressure valve in the rail is stuck open.
Old Jun 24, 2012 | 06:08 PM
jetmedic's Avatar
I hope that's it I'm fixin to buy a cp3. But I'll try Fca first. You just shake it from what I hear.
Old Jun 25, 2012 | 09:39 AM
JimmyT's Avatar
unplug your FCA then try and start it. If it starts and rattles really bad, then your fca is bad. Make sure you turn it off right away if it starts. Your rail psi will be over loaded with fuel.
Old Jun 25, 2012 | 01:59 PM
jetmedic's Avatar
Thanks jimmy
I do have code P0483 fan clutch.
Old Jun 28, 2012 | 05:54 PM
jetmedic's Avatar
I removed cascade overflow valve and found metal flakes in the valve. Does that mean CP3 bad? I just want to fix this darn thing.
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
