Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
NEED HELP ASAP Need truck tomorrow morning! Electric brake controller install.
Old Jun 21, 2012 | 03:24 PM
cummins freak's Avatar
Default NEED HELP ASAP Need truck tomorrow morning! Electric brake controller install.
Ok guys my 2005 3500 doesent have a towing pkg. or a 7-pin harness. so i picked up a 7-pin adapter that hooks to my current 4 pin plug. I also pick up a brake controler and pig tail that plugs into the controller and under the dash. controller has power and lights up when manually activated. so heres my question.
my 7-pin female end has 4 more wires
black-needs fused/keyed power.
Q) where woud you hook this one up?
Q) is there a wire i can tap in the rear?
purple-is reverse
white- is ground im gonna screw white to the frame.
blue - is brake controller
Q) can i just run this up to and splice it in to the pig tail from the controller to the hook up under the dash?
wiring is not my thing
Old Jun 22, 2012 | 11:36 AM
BucktownPSD's Avatar
Wow I can't believe that truck didn't come with a towing package. I could be wrong, but I thought there is a harness behind the bumper. You should be able to by a 7-pin that will connect to that harness. You just disconnect it and put the harness from the 7-pin inbetween.
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
