94-98 12V Cummins 5.9L P7100 Tech Talk '94-'98 5.9L Cummins 12-Valve P-9100 Tech Articles
Governor Spring
Old Feb 20, 2008 | 05:53 PM
94cummins12v's Avatar
Default Governor Spring
how hard is it to replace the stock governor spring with the 4Gsk
Old Feb 20, 2008 | 09:04 PM
DieselDiva's Avatar
It's not hard. I can change the springs and adjust the idle in 30-45 minutes. The worst part is removing the plug on the pump. It can be tricky sometimes.
Old Feb 20, 2008 | 10:58 PM
stillbad's Avatar
With 4k gsk, would you need to put in some 60lb valve springs?
Old Feb 20, 2008 | 11:46 PM
DieselDiva's Avatar
We recommend 60 lb. valve springs for anything over 3250 rpm.
Old Feb 20, 2008 | 11:59 PM
ya its not required but you should just dont excede the rpm rating with out them so how do you install them and whay are there so many
Old Feb 21, 2008 | 12:23 AM
DieselDiva's Avatar
CAUTION:If you intend to operate the engine over 3200 rpm, you should replace the engine valve springs with a heavy-duty type.
Estimated completion time: (First time installer) 1.5 hours
Things you will need to complete this project:
1. 7/16" deep socket
2. 3/8" drive and ratchet
3. 10mm six point socket, 3/8" drive w/extensions
4. 8mm, 6-point 1/4" or 3/8" drive socket
5. Pliers and Pencil magnet (A magnet is VERY helpful!!)
6. Medium to large flat-blade screwdriver
7. Slim, long, flat-blade screwdriver
8. Vernier Calipers
9. 8mm Allen wrench
10. 7/8" Socket
11. Tape or clean towel to block openings
12. Fender covers (optional)
Cleanliness counts! Clean engine to keep debris and foreign objects from entering engine.
1. READ all the directions before beginning the installation.
2. Set parking brake. Automatic transmissions must be in park, manual transmissions must be in neutral.
3. Protect paint and batteries with covering
4. Using a 7/16" deep socket, loosen lower clamp on upper intake connection hose and slide lower clamp off of hose and down the steel tube out of the way.
5. Remove the six bolts holding the air intake connection and dipstick tube in place using a 10mm 6-point socket. The bolts are different lengths. They must be replaced in the correct position.
6. Remove intake manifold connection and hose as a unit. The gasket must not be damaged in this process. It can be reused but must be replaced if damaged.
7. Cover the air tube and manifold openings to keep foreign objects from falling into them.
8. There are three bolts holding the fuel shutoff solenoid & bracket to the injection pump, two on top of the AFC housing & one at the back of the pump. Remove these three bolts & the hairpin that holds the solenoid rod to the pump linkage.
9. After removing solenoid you will see a plug nut, using a 7/8" socket, loosen this plug nut. You will have to hold the linkage over to one side so you can get enough clearance to totally remove plug nut.
10. Bar (roll) the engine over until the governor spring adjusting nut comes into view, center it in the hole. Note the position and mark it.
11. Using the Vernier calipers, measure the distance from the top of the governor stud to the top of the governor spring adjusting nut. Record this measurement for the reassembling.
12. Remove the spring retainer and all inner springs (leave large spring in place). Remove inner spring seat assembly at the bottom of the bore and remove any shims that are installed. Check for shims stuck to the springs or seats. Do not reinstall shims as are they are no longer required. Use only the springs contained in your new kit. Do not reuse any of your original springs other than the large spring left in place at the beginning of this step.
13. Install new lower spring seat and springs. Install upper spring seat and adjusting nut. Adjust to the measurement noted at disassembly.
14. Bar engine over until opposite governor spring set is in position. Repeat steps 12-13.
15. Reinstall plugnut, fuel solenoid and bracket.
16. Remove air tube and manifold coverings.
17. Reinstall intake manifold connection and hose.
18. Start engine and check idle speed. A variation of plus or minus 50-60 RPM is normal and we recommend that this be adjusted using the idle screw.
Who put in the 4k's listed in your signature???
Old Feb 21, 2008 | 10:24 AM
i put it in my sig because i have the set its just not in yet
Old Feb 21, 2008 | 11:37 AM
DieselDiva's Avatar
Oh ok!!
Well, enjoy your springs! They will make your truck even more fun to drive!!
Old Feb 22, 2008 | 12:36 AM
thats what i want that and the power
ok the kit i have came with six springs and 2 plate looking things, i know that you place the medium sized one inside the big one and the small one in the medium one and then you place that washer hing on the base but what i dont get is why there are two sets do you place the other set the same way just on top or what?
Last edited by 94cummins12v; Feb 22, 2008 at 12:36 AM. Reason: Automerged Doublepost
Old Feb 23, 2008 | 10:29 PM
DieselDiva's Avatar
Do you have stock springs in there now or do you have a 3k kit in??
