Help needed to see what engine year and problems with oil pressure
Old Jun 16, 2012 | 04:32 PM
upstate29353's Avatar
Default Help needed to see what engine year and problems with oil pressure
Hello board this is my first time here.I have a problem i bought a 94 power stroke not running so i got it home and put some batts in to try to get it started i noticed i have no lpop filling up the hpop.I then filled the hpop up and still get nothing checked pressure from hpop nothing looked inside the hpop cover no oil coming in.From reading on here the 94-95 have a check valve behind timing cover i how no place for that plug would this be a newer engine everything on truck tells me its a 94 but the timing cover is different also it didnt have a ecm i used 1 from my brothers 97 would that make a differencse withy the lpop i wouldn't think so but i don't work on these things everyday
Old Jun 16, 2012 | 06:11 PM
97t444e's Avatar
did you make sure there is oil in the pan?
Old Jun 16, 2012 | 07:16 PM
yup has about 6 qts to much tach moves won't even hit on starting fluid
Old Jun 16, 2012 | 08:19 PM
97t444e's Avatar
it could very well be the lpop, once you fill up the hpop res and you crank it, is the res empty again?
Old Jun 16, 2012 | 08:51 PM
yup the lpop looks good no marks and doesn't look oem oem have 10 teeth i think this has 13
Old Jun 17, 2012 | 12:24 PM
97t444e's Avatar
could be oil pick up tube then
Old Jun 17, 2012 | 02:59 PM
i'm gonna pull thye engine tomorrow to check that can't get the pan off all the way tried with lift the engine up but still not enought room
Old Jun 17, 2012 | 03:09 PM
fordornothing's Avatar
pull the timing cover too. to make sure there isn't that check vave.
Old Jun 17, 2012 | 03:11 PM
I already pulled the timing cover no check valve in that model
Old Jun 17, 2012 | 03:41 PM
sounds like the pickup tube. also, while you have the pan off. if your dipstick tube is leaking. i'd reseal that.
