Fuel Pressure 1%? Help!!
Old Jun 16, 2012 | 11:27 AM
firstgenfreak93's Avatar
Default Fuel Pressure 1%? Help!!
I have a 2000 24 valve with an Air Dog fp 150 system edge juicw with attitude and newer injection pump and yesterday my fuel pressure dropped to 1% and now it will start for a second and the die. It wont run at all. Some people told me my Air Dog system went out. Is that all it is. truck has 230xxx on it.
Old Jun 16, 2012 | 12:46 PM
Sounds like the AD has died or the filter is stopped up.
Luke
Old Jun 17, 2012 | 06:03 PM
empty wallet's Avatar
Did you have lift pump on block or in tank? possible restriced flow
Old Jun 17, 2012 | 06:42 PM
RAW's Avatar
RAW
1% ? 1PSI??
Old Jul 4, 2012 | 06:23 PM
gruffysram's Avatar
i thought they the engine would still run even with a crapped out lift pump and thats what can damage the vp44?
Old Jul 11, 2012 | 11:43 PM
TechJR's Avatar
Verify lift pump power, turn the key to crank BRIEFLY and then release, should hear the pump run for 25 seconds.
- Verify lift pump pressure before the filter, then at the injection pump, and make sure its actually fuel at both points, not just air pressure.
- If you don't have fuel before the filter, physically verify your fuel level and if its good then your lift pump is bad.
- If you the lift pump doesn't run at all then first check the wiring to the plug and make sure you have 12V supply after bumping the key to "start." The power is supplied DIRECTLY from the engine ECM so there are no fuses for the lift pump alone. If you don't have power to to pump then make sure the ECM has power, turn the key to run and see if the "wait to start" and "check engine" light turn on. If not then its likely your ECM has lost power.
- If you have fuel to the injection pump and its still not starting, check out Blue Chip Diesels troubleshooting page VP44 Diagnostic, I've been a diesel tech for 4 years now and I still learned from his tips
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
