need injectors
I figured that was the reason... You have a long way to go before you assume a failed Cont test...
What symptoms do you have otherwise?
it runs like crap. hard to start and then it has a miss. gets worse if you turn the chip.to a higher power. so you're telling me that even though it failed a contribution test that the injectors may be OK?
I'm telling you that a failed contrubution test does not say "INJECTORS". It may very well be injectors, but it would sure suck to spend $500 bucks on 3 new injectors to find out you have a bad UVC, or a fuel system problem.
That PDF I threw up has some good info.
Thanks for the info, I've got some work to do before I can even troubleshoot it now. I just crawled under it and apparently the frame mounted fuel pump went out so the previous owner spliced in some parts store fuel pump before it. Didn't even bypass the old one. I figure that could be part of it. I doubt it'll run right after I fix that but it'll keep from messing more stuff up.
