86 6.2 smokes a lot and sputters under acceleration and at idle
Old Jun 14, 2012 | 09:01 PM
Joe Kapitany's Avatar
Default 86 6.2 smokes a lot and sputters under acceleration and at idle
got an 86 k5 with 6.2 and it starts really easy just runs reall choppy and puffs out quite a bit of white smoke and doesnt go away, havent checked the glow plugs or anything and its misses or sputters under moderate acceleration and high rpms had this truck a week and its my first diesel has 175k miles on it, any ideas?
Old Jun 15, 2012 | 02:31 AM
cviola2005's Avatar
i'd say the piston rings are worn out. mine runs good but white/blue smokes alot. Alot of blowby.
Old Jun 15, 2012 | 11:02 AM
its not blue smoke, it smells like diesel but it might be a mix, what is blowby?
Old Jun 18, 2012 | 11:15 AM
cviola2005's Avatar
cylinder compression blowing by the piston rings into the crankcase.
Old Jun 18, 2012 | 06:13 PM
ebarresi5894's Avatar
could be leaky injectors, or a bad head gasket/head.
how much white smoke on start up?
Old Jun 19, 2012 | 04:48 PM
it smokes quite a bit at startup but once it gets warmed up its not so bad but still does a little and it doesnt smell like coolant just like raw fuel. And the truck runs at about 150 F when its fully warmed up. i notice that is smokes mainly when i let off the throttle while driving and its got true dual exhaust and both sides smoke
Old Jun 19, 2012 | 09:06 PM
sounds like a head gasket issue, how is the coolant? how is the oil?
Old Jun 19, 2012 | 09:25 PM
the oil didnt have any water in it that i could tell when i changed it which was saturday and it doesnt leak or use any oil that i could tell. but i will check the coolant level tomorrow after duty if i get a chance
what about advancing the injection pump a little bit? not sure how this could have got out of time at all, i looked and the marks lined up but maybe the chain stretched. like i said im new to diesel and it comes out of both exhaust pipes so i hope both head gaskets arent bad
Last edited by Joe Kapitany; Jun 19, 2012 at 09:25 PM. Reason: Automerged Doublepost
Old Jun 20, 2012 | 05:49 PM
if you have access or experience in trucks, you can do a compression test.
if not, bring it somewhere and have them do it.
or, take the glow plugs out and se if coolant pees out of the hole
Old Jun 27, 2012 | 02:03 AM
cviola2005's Avatar
my truck ran exactly the same as you describe yours runs. i advanced my injection pump timing and turned the fuel screw in a smidge and it has virtually quit smoking.a few puffs randomly as it idles and thats it
