Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
HELP WITH VHF 2-WAY RADIO
Old Jun 12, 2012 | 08:58 PM
smokeeaterlb7's Avatar
Default HELP WITH VHF 2-WAY RADIO
OK, so heres the deal, I have a 2 way mobile radio for thee volunteer fir department i am on. wheen i wire it up, (good power supply, good ground) and key in the accessory or off position, it works GREAT. but when i turn the key on, i get all sorts of interference until i unhook the attenna, then no interference what so ever. DOES ANYONE HAVE ANY IDEA WHY IT WOULD BE DOING THIS? If it is any help, we just switched to narrow band radio frequency today.
Old Jun 12, 2012 | 09:12 PM
HoboCoastie's Avatar
I usually install a noise filter in line with the power to remove ignition interference. You can pick one up at Radio Shack for like $9? It'll quiet it down quite a bit.
Old Jun 12, 2012 | 09:49 PM
i finally tracked down the problem. The HID headlights are somehow backfeeding the power system and causing the interference
Old Jun 12, 2012 | 10:14 PM
The filter right behind the radio would still help alleviate the noise.
Old Jun 12, 2012 | 10:20 PM
H.R.D's Avatar
Is your antenna wire ran close to the headlight wires? If so try to run it else where. You can also use some metal jacket or tin foil to use as more insulation.
Old Jun 12, 2012 | 10:46 PM
i am going to try the noise filter tomorrow, but the antenna wire is no where close to the headlight wires. I have tried 3 different antennas with the same result. If the noise filter does not work, then i am going to put my headlights back to the stock bulbs. I can do without those.
Old Jun 13, 2012 | 04:51 AM
Deezel Stink3r's Avatar
Very good idea!
Just add a ground cable to the shielding, otherwise it is useless.
The ground cable is grounded only in a single point- not on both ends-otherwise you create another loop.
Make sure all your additional connections(return and live wires!) go directly to the battery. Do not interfere somewhere in the truck harness. This causes interference in most cases to ground or live loops.
Filters are wasted money, if you know the ropes how to avoid noise.
Old Jun 13, 2012 | 06:29 AM
Try turning your wipers on while the radio is on...You'll probably hear those too.
Old Jun 13, 2012 | 07:55 AM
You know the reason for that noise?
Lack of proper grounding-again...
Old Jun 13, 2012 | 10:20 AM
Originally Posted by Deezel Stink3r
Very good idea!
I removed the radio from the truck, had it sitting on the firewall, hooked up. wires not close to any other wiring on the truck. turn the key to on, headlights automatically come on, static starts. i manually turn off the headlights, and the static stops.
