Need help fast!! Stranded at Walmart in fire lane...
Old Jun 10, 2012 | 02:30 PM
Ltk's Avatar
Ltk
Default Need help fast!! Stranded at Walmart in fire lane...
Turned my truck off a few minutes ago, now it turns over slowly but won't start... Any ideas as to what it could be? I don't have many tools on hand but need any Info fast please!!!
This is embarassing
Old Jun 10, 2012 | 02:44 PM
1999stroker's Avatar
Battery
Sent from my DROID BIONIC using Tapatalk 2
Old Jun 10, 2012 | 02:46 PM
Ltk's Avatar
Ltk
It's not the battery or connections we've tried those and jumper cables won't work either. Acts like its not getting fuel
Old Jun 10, 2012 | 03:16 PM
You try prime the system? What do u drive sry
Old Jun 10, 2012 | 06:30 PM
stuck67's Avatar
have you tryed throwing ice water on the crank postion senser ford has a recall on them i had one go out on me on vacation
Old Jun 10, 2012 | 06:45 PM
farmerdude's Avatar
could be starter going out. had one do the same thing to me.
Old Jun 10, 2012 | 07:38 PM
Ltk's Avatar
Ltk
The starter seems fine. It acts like its not getting fuel. I have to test the fuel pump when I get home...
I thought the CPS was only problematic on the 7.3's
Old Jun 10, 2012 | 08:29 PM
wildbill's Avatar
When you say turns over slowly, it's as the engine isn't getting spun over fast enough or what do you mean exactly?
Old Jun 10, 2012 | 09:15 PM
Ltk's Avatar
Ltk
Yes its as if the engine isn't turning over fast. But when pushing gas in and out it turns a little faster, but it sounds strange
Old Jun 10, 2012 | 09:46 PM
bobfbigman's Avatar
pull the connection off the ICP sensor and see what it does. Have you tested your FICM??
