Gauge Cluster Problems
Old Jun 8, 2012 | 06:58 PM
DieselObsession76's Avatar
Default Gauge Cluster Problems
The entire gauge cluster on my 99 24v keep going out randomly... they'll stay on for a while then if I shut the truck off they wont come back on, but sometimes they'll stay on for 2-3 days, and even when they dont work the lights on them still do and my WTS and Parking Brake lights will still come on... I've had the cluster out and checked all the plugs and the wires that I can see and everything seems ok... I need help, I dont know what I need to be looking at
Old Jun 8, 2012 | 07:25 PM
Whit's Avatar
Site Mascot
the gauge cluster is feed power from the fuse block at the left of the lower dash............pull the fuse and make sure the contac point are good and clean
so I take it that its not blowing fuses correct.............if so than this is a power interuption of some sorts
Old Jun 8, 2012 | 07:27 PM
No sir it didnt blow the fuse, the ends are kinda yellowish, is that no good or doesnt it matter?
Old Jun 9, 2012 | 10:45 PM
TTT Still no solution
Old Jun 18, 2012 | 01:38 PM
dmaxjenn's Avatar
IT'S A GIRL!
Weak circuit board .
Remove the cluster and with a bright light and magnifying glass look for a cracked solder run. Also look for compromised connections in the wiring pin out.
Dbleo351
Nov 20, 2016 09:34 AM
Powerstroke36
Sep 21, 2015 08:32 PM
MrCat4974
Mar 23, 2015 11:30 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
Ibanimal
Oct 31, 2014 09:07 AM
