Chevy/GMC Duramax 2011 LML Discussion of Chevy and GMC Trucks with LML Duramax Turbo Diesel Engines
Tsb's on the 2011 -2012 LML
Old Jun 8, 2012 | 03:21 PM
dmaxjenn's Avatar
IT'S A GIRL!
Default Tsb's on the 2011 -2012 LML
date tsb #
Apr 19, 2012 /08-06-04-040A Engine and or Fuel System - MIL ON and or DTC's P0171 and or P0174 Set
Apr 19, 2012 /12036 Recall - Windshield Wipers May Become Inoperative
Apr 19, 2012 /12045 Campaign - Ignition Lock Cylinder May Bind
Apr 24, 2012 /03-00-89-008F Body - Metal Body Panel Corrosion Protection
Apr 24, 2012 /12063 Campaign - Uneven Brake Pedal Feel
Apr 26, 2012 /12050 Campaign - Rear Axle Grinding Noise and or Vibration
Apr 30, 2012 /11290 Recall - MIL ON and or Lack Of Power and or Runs Rough
May 3, 2012 /11342E Campaign - Enhancements For Side Impact Pole Performance
Apr 27, 2012 /09-08-57-002C Body - General Water Leak Diagnostic Guide
Apr 30, 2012 /06-08-51-005B Body - Hem Flange Sealer For Corrosion Protection
Apr 30, 2012 /10-06-04-004B Engine Controls - MIL ON and or DTC P0172 Set
May 2, 2012 /00-06-01-026D Engine - Intake Manifold Inspection and or Replacement
May 2, 2012 /06-07-30-023E AT - 1-2 Shift Shudder at Light to Moderate Accel.
May 3, 2012 /09-06-93-003C Diesel Engine - MIL ON and or Multiple DTC's Turbocharger VPS
May 3, 2012 /11-08-61-002C Body and or Frame - Noise from Underbody Over Bumps
May 3, 2012 /12-04-21-001A Drivetrain - Transfer Case ID First Design Vs. Second
May 3, 2012 /12-06-01-003 Engine - Repairing Engine Front Cover Oil Leak
May 4, 2012 /07-09-41-001C Restraints - Air Bag Status Indicator Switches ON and or OFF
May 4, 2012 /12-08-44-002 Audio System - Radio Software Update
May 7, 2012 /12082 Campaign - Rear Differential Seal Leak
May 9, 2012 /09149B Recall - Front Brake Hose Fitting Corrosion
May 9, 2012 09226B Recall - Fuel Odor Or Spotting On Ground
May 9, 2012 /12-06-01-001A Ignition and or Engine - MIL ON, Engine Running Rough and or DTC P0300
May 10, 2012 /09-07-30-004I AT - Shift Flare and or Harsh 2-3 Shifts From Park To Drive
May 14, 2012 /12-06-01-004 Engine - Engine Mount Clunk Noise and or Leaking on Police Vehicles
May 15, 2012 /08-05-23-006H Brakes - FNC Brake Rotor Noise and or Pulsation
May 15, 2012 /12-00-89-004 Tires and or Wheels - Snow Chains Now Approved for Caprice PPV
May 15, 2012 /12-05-25-001 Suspension - 'Service Stabilitrak' Message While Stunt Driving
May 15, 2012 /12-06-01-005 Engine - Info When Transferring Plastic Parts to a New Engine
May 15, 2012 /12-08-64-001 Door Locks - Loss of Power Door Lock Function
May 16, 2012 /05-08-46-006R OnStar(R) - Analog and or Digital Ready System Digital Upgrade
May 16, 2012 /H12-10-05 Body and or Frame - Front End Module Replacement (Collision Repair) May 17, 2012 /07-03-10-008C Tires - Slight and or Mild Edge Feathering Information
May 17, 2012 /09-07-30-012E AT - No Reverse and or 3rd or 5th Gear and or MIL ON and or DTC P0776
May 18, 2012 /09-08-64-035D Body - Side Doors Stick Using Outside Handles When Hot
May 18, 2012 /12-05-26-001 Brakes - Resurfacing Park Brake Portion of Rear Brake Rotor
May 18, 2012 /Campaign - Fuel Filler Neck Corrosion
May 21, 2012 /11290A Recall - MIL ON and or Lack Of Power and or Runs Rough
May 21, 2012 /11340A Campaign - Timing Chain Wear
May 22, 2012 /H12-TAC-02 Interior - Creak Noise from Driver Seat
May 23, 2012 /12-08-57-001 Electrical - Water Leak Causes Weak and or Dead Battery and or No Start
May 23, 2012 /10183A Campaign - Power Steering Assist Loss of Power
May 23, 2012 /10187A Campaign - Power Steering Loss of Power Assist
Nathanator
Aug 26, 2015 06:25 PM
