99-03 7.3L Performance Discussion of 99-03 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
7.3 edge juice
Old Jun 4, 2012 | 11:48 PM
7.3-POWER-STROKER's Avatar
Default 7.3 edge juice
i have a 02 f-350 my edge fried my pcm and idm thats what the codes pulled up said i replaced both and still no start, any ideas what could be causing the problem it will cank over but will not get any rpm's also changed the cam senisor and still no luck, i would love any advise anyone has!
Old Jun 5, 2012 | 12:33 AM
A/Ox4's Avatar
Did you take the edge off? If it blew a PCM I would hope you didnt put it back on... FYI, no 02 or newer truck will show RPMs on the tach while cranking.
Old Jun 5, 2012 | 09:45 AM
CSIPSD's Avatar
Its simply not possable for the Edge unit to "fry" your IDM... PCM, MAYBE... thats a big maybe.
Get a scanner on it and see what the ICP pressures are doing.
Old Jun 5, 2012 | 11:45 AM
shorty2tall's Avatar
Did u call edge I had the same problem with my edge Evo when I first got my truck then they walked me through how to fix it. and most of us here use dp tuners and ts chips so idk if anyone will be able to help u out as much as edge could.
But after edge walks u through how to fix it if ur still doesn't work then I would say more then the tuner.
Patrick
Old Jun 5, 2012 | 11:47 AM
Also when cranking does smoke come out the tail pipe?
Patrick
Old Jun 5, 2012 | 10:23 PM
articfox's Avatar
how can a edge unit fry pcm? ive had mine for a while and few people i know who has them never had a problem with mine gonna sell it soon going to go with a ts chip
Old Jun 6, 2012 | 05:27 PM
fordornothing's Avatar
i can personally say that edge smoked the PCM in my 96. i changed tunes and right towards the end of the flash process, it did some weird triangle,to square, to trapaziod pattern on the screen. i thought it was ok ish so i fired it up and it loped 3 times and quit. PCM was cooked. but that was with a basic edge evolution.
Old Jun 6, 2012 | 05:47 PM
joebob3093's Avatar
Moderator
I ran the edge evo for a few years and never had a problem.
Old Jun 7, 2012 | 07:50 AM
Ya has an attitude tho which is in the fly compared to the Evo which isn't.
But OP any luck with the truck yet?
Patrick
Old Jun 7, 2012 | 05:00 PM
POWERSTROKEMANIAC's Avatar
Ive heard and seen many cases of EDGE tuners smoking PCM but 75% of the time they were in 6.0s
