How much fuel pressure is too much?
Old Jun 4, 2012 | 06:17 PM
skav's Avatar
Default How much fuel pressure is too much?
I had a problem w my FASS 180, so I ordered a replacement pump. It came in today, so I installed it and primed the system.
Once the truck fired, I noticed that my 30psi fuel pressure gauge is now pegged. Before the replacement pump, I had 25psi at idle and around 21 when I was on it.
Is this too much pressure for a II hot rod 44?
It starts fine and idles, but I haven't driven it yet.
Old Jun 4, 2012 | 06:20 PM
Red_Rattler's Avatar
High Tech Redneck
25 is way more then enough and if the gauge is pegged now I'd def find the cause of it befor it hurts the pump.
Old Jun 4, 2012 | 07:41 PM
skav's Avatar
Thanks. Somebody told me that a lot of guys run 50psi. That seems like a ton to me.
I was told that there is a screw you can adjust on the FASS to reduce the pressure.
Has anyone done this before?
Old Jun 4, 2012 | 09:25 PM
High Tech Redneck
Yea 50 psi on a p pump is normal and if yours is adjustable its easy to do, just loosen the jam nut and adjust the allen screw to your desired pressure and tighten it back up. Fass reccomends 8-12 psi but Id be shooting for 20
Old Jun 4, 2012 | 09:29 PM
skav's Avatar
RR, this is on a VP44. I'm not sure how much different it is than a p pump, but supposedly you can change a spring or adjust a screw on the FASS to reduce the pressure.
Old Jun 4, 2012 | 09:33 PM
RAW's Avatar
RAW
The two pumps are very different. The recommended pressures listed above are for a VP44.
Old Jun 4, 2012 | 09:35 PM
skav's Avatar
I just swapped in another gauge, and it's reading 40psi!
Old Jun 4, 2012 | 09:41 PM
RAW's Avatar
RAW
That just doesn't seem right at all! How old is your pressure relief valve in the return port of the VP? MIght be a good idea to change it, and adjust the FASS. What FASS do you have again? I'm not finding a 180.
Old Jun 4, 2012 | 09:59 PM
skav's Avatar
I may be confusing the Airdog 180 on the Ford. It's a FASS 150. I checked the return valve and it looks good. I just cut the spring in the FASS and it dropped to 31psi. I'm going to cut it a bit more and try to get it to 20-25psi at idle.
Old Jun 4, 2012 | 10:30 PM
skav's Avatar
I finally got it to idle at 23-24psi. I'm surprised how much of the spring I had to cut!
I think I'll order another spring and ball to keep as a spare.
I don't know why FASS doesn't make an externally adjustable bypass instead of the internal spring. Kinda a PITA to get it right
