motor and tranny swap
Old Jun 3, 2012 | 07:18 PM
jamesrett's Avatar
Default motor and tranny swap
I have two F-350's, one 96 and one 97. I'm pulling the motor out of the truck with and auto tranny and its going in to a truck with a 5-speed. A couple questions. 1, the auto motor looks like it has a 1 inch adapter plate, does that also mate up to the 5-speed. While I have the motor out is there any things i should do power wise or maintance wise. this is my first diesel and any help is appreciated. I should also mention it came with a Edge evelution 15000 programmer. Thanks for your help
Old Jun 3, 2012 | 08:48 PM
CSIPSD's Avatar
Need to remove the spacer for the manual... The auto spacer is thicker.
Old Jun 3, 2012 | 09:20 PM
jamesrett's Avatar
Is there a spacer for the 5-speed, or does it just mount to the block?
Old Jun 4, 2012 | 12:15 AM
CSIPSD's Avatar
I believe there is a small spacer, but its been a long time since I have been under a rowboat.
Old Jun 4, 2012 | 08:06 AM
joebob3093's Avatar
Moderator
Yes there is a spacer that goes behind the flywheel. If you forget it you will know when you try to mount the starter.
Old Jun 4, 2012 | 01:51 PM
jamesrett's Avatar
Ok. Thanks. I'll make sure I have all that. I better get me a chilton's while I'm at it. Lol
