New guy need help with code
Old Jun 3, 2012 | 04:32 PM
jeeper38's Avatar
Default New guy need help with code
So I have a code P2127. I know that it is referring to the Pedal Position Sensor, but here's the history of the problem. I changed the Fuel filter back in December when I changed my oil. The truck threw the code. I cleared it. It threw the code again a few days later. I cleared it again and it never returned until today. I just had six new injectors put in professionally and got the truck back yesterday. They also Changed the Oil and Fuel Filter. I am wondering if there is anything that could get bumped by an elbow or hand to make this code get thrown. Just seems strange that I have got this code both times the fuel filter has been changed. I cant get the code to clear this time either. Thanks for any ideas.
Old Jun 7, 2012 | 10:38 PM
Anguss's Avatar
Do u have adjustable pedals? If so, Poor design, and if adjusted (to fit someone else) sensor pops off of back of gas pedal. Just put it back on.
Old Jun 8, 2012 | 01:21 AM
H.R.D's Avatar
Just to clearify its called an accelerator pedal not a GAS pedal. We put DIESEL in our trucks not gas.
Below is a picture of the pedal and the sensor...This is out of an 06 truck so I am not sure if it is the same for the OP's.
Old Jun 8, 2012 | 06:55 AM
Anguss's Avatar
OP, just check to make sure the sensor is firmly attached to the "accelerator pedal", you may have to lower the pedal adjustments (if adjustable). To reset the code, unless you have a code reader/programmer like Edge, Smarty, etc, just unhook both batteries for about 10mins and should work.
H.R.D., thanks for the clarification and your Show N Tell from school. I'm sorry to hear yours only eats diesel.
Old Jul 11, 2012 | 09:27 AM
jfmg68's Avatar
To be correct DIESEL is a form of gas just like gasoline is a form of gas. So if it is a gasoline or diesel engine (not a motor) we still fill up with gas.
Old Jul 11, 2012 | 01:01 PM
H.R.D's Avatar
Your welcome jackass may next time you will use correct terms. haha
Really? You do realize GAS is short for GASOLINE right? Yes they are both petroleum products but gas and diesel are not the same. They are refined from petroleum to produce certain chemical properties which are unique to diesel and gas.
Old Jul 11, 2012 | 02:10 PM
jfmg68's Avatar
GAS is short for GASOLINE right? NO IT IS NOT
Do you now gasoline and diesel is a liquid and when it goes in your cylinder it turns into a gas (not a liquid anymore).
So to your correction it can be call a GAS pedal.
Why we are on the subject everyone is calling fuel nozzles fuel injectors, they are called fuel nozzles.
Old Jul 12, 2012 | 01:16 AM
H.R.D's Avatar
Please pull the trigger on yourself....that is all!
It does not turn in to a gaseous state as in solid, liquid, gas. It turns in to microscopic mist particles that mix with air (atomization). It is still in a liquid form and not in a gaseous state to which you think. Far as a fuel injector/fuel nozzle the entire body, plunger, and nozzle (among other parts) make up a FUEL INJECTOR. A FUEL NOZZLE is where the the fuel is emitted from.
dwmeehan
Sep 6, 2015 04:20 PM
1ATony
1A Auto Parts
Aug 3, 2015 10:35 AM
flash7210
Jul 5, 2015 09:25 AM
rowekmr
May 31, 2015 09:03 PM
robbyS
Apr 16, 2015 02:22 PM
