F-Bomb hellfire
Old Jun 1, 2012 | 12:36 AM
Codyhuff's Avatar
Default F-Bomb hellfire
Is it alright to run f-bombs hellfire diesel additive it 1992 7.3idi and if so what would I gain from using it?
Old Jun 1, 2012 | 05:09 AM
DieselCrawler's Avatar
never heard of it. and gains? probly nothing but a lighter wallet.
Old Jun 2, 2012 | 08:46 PM
4x4manonbroke's Avatar
LOL.... yeah add a quart of atf to your tank..... that will clean and add a bit more punch to it.... i run atf all the time..... lubes pump and all that good stuff...
Old Jul 7, 2012 | 06:06 PM
ALWAYSREADYROB's Avatar
can you run an IDI on used filtered ATF ? Veggie oil is getting scarce in SOCAL ! you think it was liquid gold or something.
Old Jul 8, 2012 | 08:01 PM
aslong as it is filtered, an idi will run on WMO, WATF, WHF. just it will wear out pumps and injectors faster due to a higher carbon content.
Old Jul 8, 2012 | 10:20 PM
well our wondeful low sulfur fuel will do the same due to lack of lube.... guess were screwed either way sounds like.... a little W/ATF will do some good I would think, as long as ya dont use too much... like I run 1 qt to 19 gallon tank...... and if I have enough fuel 1 gallon of waste filtered oil to 10 gallons of #2fuel...like to run #2 B5 better... that 5% bio makes a difference in power, smoke , and econemy in my truck.... from what testing I have done.
I can see how the wmo can carbon up stuff a bit.... i try to run it light
