turbo change
Old May 26, 2012 | 01:05 AM
silverbeast1345's Avatar
Default turbo change
im thinking of replacing my turbo with a hollset hx40 any body have any thoughts on this
Old May 26, 2012 | 07:42 AM
empty wallet's Avatar
Do you not like your 66?
Old May 27, 2012 | 05:17 AM
i havent had a problem with the 66 it's pretty lagy im looking for something thats going to spool quicker
Old May 27, 2012 | 07:36 AM
I'd get a 62mm or 64mm
Luke
Old May 27, 2012 | 08:59 AM
cummin_un_glued's Avatar
FormerVendor
S363/68/.80T3 gated
Old May 28, 2012 | 05:09 PM
Just give the 66 the fuel it requires... your injectors are way too small
Old May 28, 2012 | 09:46 PM
FormerVendor
give any thought to the fact that hes got 150s with 4:10s and maybe he isnt looking to make 700hp and would still like to tow with it
Old May 29, 2012 | 08:52 AM
i was just looking for something that will give me boost in the 40 to 50 pound range and will keep my egts down
Old May 29, 2012 | 08:56 AM
FormerVendor
63mm will make all the boost you need and keep your 150s cool enough to tow with. I would imagine you silver bullet is so slow to spool that its causing your egts to rise.
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old May 29, 2012 | 04:42 PM
I didn't give that any thought because he never said he wants to tow anything and I have 4.10 gears I think that's an advantage with a 66... he obviously wanted to run the turbo, I say before copping out atleast set it up properly and see how it is. 250hp injector is what you need.
