2008 will not shift past 4th after screwing up update on mini max
Old May 20, 2012 | 08:51 PM
xjrev10's Avatar
Default 2008 will not shift past 4th after screwing up update on mini max
I went to do the Hot Damn tune update tonight.
I have a mini max, overdrive trans, deleted.
I screwed up and ended up downloading the whole system. Screwed up all my settings, because I reloaded the whole thing.
The trans tune is gone, it says "locked."
Truck will not shift past 4th gear now. WTF did I do?
Any problems driving the truck 170 miles in 4th gear besides crappy mileage?
__________________
Old May 21, 2012 | 10:41 AM
xjrev10's Avatar
Firmware took a bit to update. Problem solved. HS awesome on the phone!
