99 cummins fuel tank module leak
Old May 18, 2012 | 10:51 AM
99RAMS's Avatar
Default 99 cummins fuel tank module leak
I have a significant fuel leak that is coming from the fuel module area. I'm in the rust belt, and the two elbows that come into the plastic module seem to be rusted pretty bad, so I would suspect the leak to be coming from there. ALTHOUGH when I looked around down there with it running, I could not see any leak. So two questions...
Has anyone repaired these lines without replacing the module itself? I know the feed line wont be under any real pressure, but the return? Would that be the leaker?
And if not, where can I find a replacement module ( besides a dealer, hopefully )...I've checked the normal auto parts places and they have nothing, and I haven't seen anything online either. HELP!
Old May 19, 2012 | 11:55 AM
dmaxjenn's Avatar
IT'S A GIRL!
try this site... Auto Parts Direct To You awesome and fast.
If you try using propane to find a leak, it will cause the motor to hesitate or gasp then you will find the leak. so run a bottle of it around the leaky areas.. then youll know where it comes from.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
