srw lift kit on drw truck?
Old May 17, 2012 | 08:43 PM
CMCA Swartzkrautheim's Avatar
bulb srw lift kit on drw truck?
so my buddy has an 02 superduty crew cab sb i have a 99 ext cab drw super duty can we just swap spings shackles and shocks?
Old May 18, 2012 | 12:24 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Im guessing the front would be the same, the back will probably be different
Old May 19, 2012 | 10:38 PM
i was hoping we could just swap springs shocks and shackles oh well, i guess ill be buyin some 3 inch stock and making a leveling kit...
Old May 20, 2012 | 10:37 AM
Karls03's Avatar
If everything matches I don't see why it can't be changed. However, the rear spring rate of the 1 ton may be higher than the 3/4 ton. A quick internet search or Q/A session with dealer could resolve that.
Old May 20, 2012 | 10:52 AM
cummins freak's Avatar
ususally lifts are for half tons and then for 3/4 and 1tons so there should be no real difference unless ford changed something from 99-02 in the rear ie spring width or something funky
Old Jun 24, 2012 | 03:49 PM
fordornothing's Avatar
the ONLY difference in the 3/4 ton to the 1 ton springs are the blocks on the rear end. everything else is the same. my buddy has a 2000 3/4 ton, his has the overloads while my 99 1 ton dually doesen't. explain that one!
slowstroke
For Sale
Mar 27, 2015 05:19 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
turbodiesel123
Oct 24, 2014 10:27 PM
Oct 14, 2014 08:40 AM
ryanf
Oct 13, 2014 10:14 AM
