Cummins 6sp manual noise
Old May 14, 2012 | 08:47 PM
leugers27's Avatar
Default Cummins 6sp manual noise
I just got back from Texas with my new truck. Its a 2003 cummins 6speed manual. When i take off and lug my truck the transmission growls or chatters but as soon as i give it more throttle and speed up it goes away and is great but this noise is annoying. I talked to a diesel guy and he said its nothing to worry about at this time. Any feed back would be great i would love to know what its coming from.
Old May 14, 2012 | 09:11 PM
First of all - dont lug it. these newer engines are made to rev.
Make sure it has the correct fluid. i would change it to be sure use amsoil.
Mine has a bit of a chatter havent had any trouble with it
Old May 15, 2012 | 01:05 PM
justinram's Avatar
Quick thought. It could possibly be a aftermarket clutch, such as a Valair or Southbend dual disk which will cause chatter at times. You may want to check with previous owner as to any upgrades he/she has done. I have an 2005 that I have owned since she was brand new. I could hear a little chatter every once in awhile but, I can hear it more now due to the dual disk I put in it. Hope you enjoy the new buy!!!
Old May 15, 2012 | 05:32 PM
leugers27's Avatar
Thanks for all the feedback. What kind of amsoil? Weight and such? Im new to diesels.
Old May 16, 2012 | 01:15 AM
Here ya go - AMSOIL Synthetic Automatic and Manual Transmission Fluid
Old May 16, 2012 | 01:17 AM
Originally Posted by justinram
Quick thought. It could possibly be a aftermarket clutch, such as a Valair or Southbend dual disk which will cause chatter at times. !
That is a good thought....
Old May 16, 2012 | 07:04 AM
steved's Avatar
Its likely "Power Critical Moment" noise...a normal chatter in manual transmissions at low speeds. If it goes away with throttle input, its likely not an issue.
A double disc will only make noise when the clutch is disengaged, when engaged they are as quiet as any other clutch.
Old May 16, 2012 | 07:10 PM
Valair1's Avatar
FormerVendor
A heavy duty clutch, single or dual can cause a low rpm growl, and or noise in the transmission when your foot is off the clutch and idling, and it usually goes away when you up the rpm's a bit. Anything that can cause your diesel to produce more spike, like a bad fca valve, missfiring injector etc... will cause the noise to be louder. In most cases it is not doing any damage and is reconized as the nature of the beast. Welcome to the world of diesels.
Old May 16, 2012 | 10:27 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i been getting good feed back with guys running dual disc with fluid dampners. they say it really takes alot of the noise out.
Old May 17, 2012 | 08:11 AM
Valair1's Avatar
FormerVendor
Understandable, that would smooth the engine a little and remove some spike
