Oil In The Coolant, Oil Looks Ok
Old May 13, 2012 | 03:07 PM
4x4manonbroke's Avatar
Default Oil In The Coolant, Oil Looks Ok
Ok so after a lomng trip (600+ miles) I now have some oil floating on top of my coolant in the radiator...... oil cooler ??? I do still have a headgasket thats seeping oil out of the passengerside head.... should I just pull motor and do it all.... or just do the oil cooler and see where she leads me... almost have the enitre truck rebuilt.... only need to do the head gaskets and the t-case..... wich blew up on me this last tuesday on my way to work.... took off from a stop sign and BANG !!!!!... nothin... got er in 4 low and managed 20mph for the 3/4 mile to work..... so how hard is a borg/warner 1356 t-case to rebuild anyways??
Gonna need some help guys....... I have a 205 out of my chevy.... tempting... wrong side drop out though....
Old May 13, 2012 | 07:09 PM
DieselCrawler's Avatar
oil cooler needs rebuilding. i have a thread here on how to do it.
as for the tcase, it is junk. most likely the oil pump locked up inside it.
Old May 14, 2012 | 11:09 PM
well I drove 300+ miles with the hubs locked in withg the t case in 2 hi......OOPS!!!!.... guess next time Iwill look that over before leaving the woods......
still cant find your stickey on the oil cooler re-build dieselcrawler, anyone got a link to the location for me ???
ur help would be awesome,
Last edited by 4x4manonbroke; May 14, 2012 at 11:09 PM. Reason: Automerged Doublepost
Old May 15, 2012 | 04:50 AM
https://www.dieselbombers.com/ford-8...er-reseal.html
Old May 15, 2012 | 10:36 PM
Awesome.... easy as pie.......... ok well I have big *** press......... So how ofter should one expect to have to do this to our trucks ??? and what is the cost of a new cooler ??
Old May 16, 2012 | 05:02 AM
new cooler is expensive. the orings and seals will cost ya less than 100 bucks.
withthe orings, i have found out petroleum jelly is best to put on them. and dont use sparingly. lather it up.
Old May 17, 2012 | 12:43 AM
what kind of frequency do you have to do the seals on these oil coolers ???
Old May 17, 2012 | 05:12 AM
your first set lasted 25 years.....
Old May 17, 2012 | 05:27 PM
7.3 idi 1990's Avatar
id get the head gaskets replaced and oil coller rebuilt and sealed
Old May 17, 2012 | 09:23 PM
why do headgaskets if it isnt a headgasked problem?
