Agricultural & Lawn Equipment Discussion of Diesels Used in Agricultural - Tractors , Lawn Mowers , Combines , Ag Equipment , Zero Turns
small engine question
Old May 13, 2012 | 01:04 PM
94cummins12v's Avatar
Default small engine question
i have a techumseh 4000 generator i bought at a yard sale runs great there are a few things id like to add to it first is a kill switch it doesnt have one on it and in order to kill it i have to pull the spark plug wire off or choke it to kill it what would be the best way to add a kill switch to something that doesnt have one alread? i hooked a wire from the top of the coil to try and ground it out but does nothing now if i hook to the same part of the coil and conect it to the top of the spoark plug it does kill it so i put it on a toggle switch and it runs like **** untill i take the wire off
Old May 13, 2012 | 02:45 PM
2004LB7's Avatar
most kill switchs are just wired in parallel with the spark plug. when you flip the switch it shorts out the spark plug and the engine stops.
for a magneto setup it would be something like this:
now if it uses an ignition coil then just use the switch to break the power to the primary side of the coil
burndiesel
10
Feb 7, 2023 01:15 AM
Dodge2006/5.9
Jul 20, 2015 01:21 PM
klein444
Jun 20, 2015 11:48 PM
GTAYLOR1956
Feb 11, 2015 06:35 AM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
