2006 intermittent rough idle
Old May 10, 2012 | 07:01 AM
Red Mega's Avatar
Default 2006 intermittent rough idle
Hello! I have been experiencing rough start and rough idle every couple of starts. Most of the time it starts and runs fine, but more frequently it has been taking a couple more seconds to turn over and then idles rough for a period of time. It doesn't do this every start, and it will settle out after driving a few miles. I recently changed out my airdog filter, but have not changed the water seperator yet (about 50k+ on seperator, new type cellulose media). Does this sound like an injector going? Anything else I can look at before blaming the injectors? How do I go about determining which injector is bad if that is the case and where can I get good quality reman. units from? Thanks!
Old May 10, 2012 | 11:46 AM
MurphyStrut's Avatar
You can take it to a stealership and have an injector kill test ran to determine if an injector isn't operating correctly.
Old May 10, 2012 | 04:32 PM
Red Mega's Avatar
Wonder how much that will cost me... Thanks for the help, if it's not an injector any ideas what route to go?
Old May 10, 2012 | 04:52 PM
cummin_un_glued's Avatar
FormerVendor
Probably cost you around $90 but if it isnt doing the rough idle at that time it wont show anything. I suggest pulling the injectors and having them flow tested. We have seen too many engines that have been drove with bad injectors and it causes serious engine damage. Ie broken rings and melted pistons.
Bench testing usually costs $30-45 each plus the labor for r&r
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old May 10, 2012 | 05:23 PM
Red Mega's Avatar
Where would you suggest sending them to be flow tested? How involved will pulling the injectors be, I have not pulled them? Thanks for the information, I really appreciate it!
Old May 10, 2012 | 05:46 PM
FormerVendor
R&R on them takes about 3 hours if your not pushing. We get $35 each to send them to a local shop. There are a few places around that do it. Scheid diesel does it at their terra haute shop.
Old May 10, 2012 | 07:09 PM
Red Mega's Avatar
What about in the southeast? The truck is my daily driver and I don't know how long I can be down...
Old May 10, 2012 | 08:48 PM
FormerVendor
Not sure but expect it to be down a week minimum
Old May 10, 2012 | 08:56 PM
Red Mega's Avatar
Thanks for the help!
Old May 10, 2012 | 09:35 PM
FormerVendor
there is Shiver diesel in FL i had a truck in here that they had put injectors in and they sent me some under warranty. seem like good guys ya might call them
