truck wont start when cold
Old May 9, 2012 | 11:22 AM
jsm5786's Avatar
Default truck wont start when cold
i have a 7.3 thats only starts when its been pluged up .it has new glow plug in it , if i dont it will only run on 5 cylinders thay say i need new injectors . will new o rings fix it , the truck works good after it runs awhile
Old May 9, 2012 | 05:59 PM
fordornothing's Avatar
how is the GPR? the running on 5 cylinders could be wiring. most likely the UVCH. how many miles on it?
Old May 9, 2012 | 06:44 PM
jsm5786's Avatar
I don't think it is a wiring issue because when it set over night they say that the injectors are leaking into the cylinders. Once it is running and I am going down the street it clears it self out and it runs like new. It has 249K miles on it. My question is will new o-ring stop the injectors from leaking fuel into the cylinders?
Old May 9, 2012 | 07:37 PM
i'm not going to say yes, but they wouldn't hurt. do all 8 injectors
Old May 10, 2012 | 02:18 PM
95powersmoker's Avatar
I doubt orings are your only problem... Sounds like an actual injector issue...
doublehbar
13
Aug 9, 2015 12:35 AM
Mike0885
May 27, 2015 12:07 PM
ronstop
Feb 26, 2015 09:48 AM
el_gringoo
Dec 14, 2014 11:03 PM
custom7.3
Nov 23, 2014 10:44 PM
