stacking chips
Old May 6, 2012 | 03:27 AM
chevyman1523's Avatar
Default stacking chips
02 duramax...good idea bad idea efi live and edge racing....I have cold air intake and have 4 in straight but was wonderin if both products would be way to much and I would meltdown my pickup
Old May 6, 2012 | 09:37 AM
BriteWhiteRam's Avatar
EFI live can do everything... there is no point to stacking with efi live, if you want more power you can tune it to do so
EFI live renders the "stack" useless because of its massive abilities to tune just about every parameter the engine allows, if you want just a small tow tune all the way up to a 2500hp drag truck, its the last electronic upgrade you will ever need for the ECM
so Im gona go with bad, stick to EFI live, ditch the edge
Old May 7, 2012 | 09:10 PM
Ok man I appreciate it does efi live have preset settings like an edge or is everything manual tuning. I don't have a problem with the manual tuning just don't wanna hurt anyting on my pickup. Also does it come with a "manual" with the tuner.
Old May 8, 2012 | 01:56 PM
1AMatt's Avatar
Site Sponsor - 1aauto
EFI live is custom tuning. If you havent done it before I would probably leave it to a professional
Old May 8, 2012 | 08:30 PM
there are plenty of shops out there that do custom tuning
duramaxtuner.com is one that quite a few guys like
You can also get a DSP5 which is a switch that allows you to instantly change between 5 pre-programmed tunes, from stock to pure race tunes that are higher quality than the Edge ones
Old Jul 3, 2012 | 09:45 AM
Michelle101's Avatar
I have an Edge performance chip in my '02 Duramax that wants to do a cranial reset everytime I shut down the engine...any ideas?
Old Jul 4, 2012 | 08:41 PM
what exactly do you mean?
Old Jul 6, 2012 | 01:20 PM
I have an '02 Duramax as well. I also have an Edge J/A performance chip that is giving me fits right now...Everytime I shut down my truck the chip does a cranial reset. When I start the truck it gives me a warning and wants me to push enter. When I push enter it works perfectly...unfortunately it has given me just one more warning! I daresent push enter...any ideas??
Old Jul 9, 2012 | 06:36 PM
you should call Edge, they should be able to help you with your problem, it sounds like it could be an electrical or electronic issue
Edge Products | 1080 S. Depot Dr. | Ogden, UT 84404| 1-888-360-3343 or 1-801-476-3343 | Mon-Fri 8 a.m. - 5 p.m. (MST)
ERK
May 22, 2015 12:11 AM
ruben24
Nov 28, 2014 08:53 AM
ruben24
Nov 21, 2014 08:13 AM
