Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
oil in C15 Cat
Old May 1, 2012 | 07:34 PM
Redram01's Avatar
Default oil in C15 Cat
I was wonder which oils becides Rotella were for the 2007 emissions motors?
Old May 2, 2012 | 10:31 AM
Heath's Avatar
Authorized Amsoil Dealer
Anything labeled API CJ-4 will work, which pretty much anything you find on the shelf today. There are still some older CI-4+ oils around, but not many.
Old May 2, 2012 | 11:08 AM
GuyWithA24Valve's Avatar
We have 15 trucks including 3 with C15s and we run the same oil as the rest of our trucks and we have had zero issues.
Old May 2, 2012 | 11:28 AM
Eddiebuntain's Avatar
As Heath said, just about any diesel motor oil on the shelf today will be compliant, if in doubt check the back label, there'll be a circle with the rating in it,and it'll also note that the oil is compatible with earlier specs. That'd be on gallon and quart jugs, I assume it'd be on the label on 55 gallon drums. If you're getting oil delivered to bulk tanks, the supplier should be able to provide a spec sheet. Just felt like overanalyzing that, thank you for your time.
Old May 2, 2012 | 12:33 PM
rufushusky's Avatar
Any CJ-4 oil will work just fine. Delo, Rotella, Delvac, Valvoline Premium Blue etc etc. Check the API donut on the back of the bottom or on the tag on the drum...should look like this:
Old May 2, 2012 | 04:11 PM
Redram01's Avatar
thank you folks a lot. The comany I work for runs mystik oil.
Old May 2, 2012 | 05:52 PM
rufushusky's Avatar
What is wrong with mystik? They have a pretty good diesel oil. No better or worse than delo, delvac etc
Old May 2, 2012 | 06:19 PM
Redram01's Avatar
I personaly never have like it.
Old May 3, 2012 | 07:06 AM
rufushusky's Avatar
Ok...bad UOA?
Old May 30, 2012 | 08:19 PM
Gas's Avatar
Gas
How can you tell a difference? Was it not slippery enough
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
Gomerpile79
Apr 9, 2015 03:45 PM
coors_man_2005
Dec 15, 2014 10:23 AM
