6.5 td lift kit
Old Apr 30, 2012 | 06:42 PM
duckslayer31's Avatar
Default 6.5 td lift kit
ive got a 1999 k2500 turbo diesel i am looking for a 3 inch suspension lift on the front any suggestions? i havent had any look finding any
Old Apr 30, 2012 | 09:32 PM
ebarresi5894's Avatar
try 4 wheelparts or jc whitney
Old May 1, 2012 | 09:06 AM
i checked both places neither of them have a lift for a 8 lug diesel
rough country is the only one i found has one but it is a 4 inch i dont wanna go that high
Last edited by duckslayer31; May 1, 2012 at 09:06 AM. Reason: Automerged Doublepost
Old May 1, 2012 | 03:01 PM
only 1 more inch
Old May 2, 2012 | 01:26 PM
great white's Avatar
3" lift on a gmt 400 is about the worst place you can be for finding aftermarket suppliers.
Torsion bar lifts (IE: cranking the keys) gets you 1.5-2 inches, Suspension lift kits start around 4". There's just no money in marketing a 3" kit for a body style that's been discontinued since 1998/2000.
Plus;Torsion bars lifts just plain suck, suspension drop kits are a PITA to install and if they're not high quality you end up with wear and durability issues.
About all I can suggest for such a small amount of "lift" is that you may want to consider a body lift kit if all you're after is to fit larger tires under it.
You'll get your bigger tires under it and still maintain you original suspension geometry.
Body lifts aren't ideal either, but it seems the best solution for the scenario you have....
Old May 4, 2012 | 09:54 AM
make sure they sell you bumper brackets with the lift, nothing will line up. also body lifts make the truck "roll" alot more.
how big of tires are you pputting on? i have 33s on my truck with the bars cranked 2 turns
Old May 7, 2012 | 07:01 AM
ive got 33's on it now and i put a leveling kit on the front and it only raised it an inch they still rub ive got 2 inch blocks in the rear allready just need something for the front i dont want a body lift
Dbleo351
Nov 20, 2016 09:34 AM
slowstroke
For Sale
Mar 27, 2015 05:19 PM
Ruddedawg5.9
Feb 22, 2015 10:54 PM
turbodiesel123
Oct 24, 2014 10:27 PM
JJ Diesel
Oct 6, 2014 11:21 PM
