Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
"The" 2 Stroke Oil Thread
Old Apr 3, 2007 | 05:53 PM
DB Admin's Avatar
Banned
Default "The" 2 Stroke Oil Thread
So To Run 2 Stroke or not reasons why and why not ?
:pc:
DM
Old Apr 3, 2007 | 06:04 PM
Uncle Bubba's Avatar
I'll go first. I think 2 stroke is a great idea and did improve mileage to a small extent. HOWEVER, I did find a downside to it. I started having fuel leaks all over the place. Both in my replacement high pressure fittings and the only stock fitting I had left on the truck. It losend all of em up better then any penetrating oil could have. Just something to watch out for if you use it.
Old Apr 3, 2007 | 07:17 PM
2001shrtbedcummins's Avatar
use it in the 24v and the 12v don't know if mileage went up with the 12v cuz I've run 2-stroke from day one with it...get 19-20mpg real easy. The 24 valve went up as well...quieted it down some. works for me...
Old Apr 3, 2007 | 07:58 PM
scarecrow's Avatar
i run it in my 01. i run the walmart supertech stuff.i noticed no gain in MPG but i did notice the engine does not knock and ping like a gasser on cheap gas and i did gain some power back
Old Apr 3, 2007 | 08:41 PM
bway1341's Avatar
I run it every tank and noticed mpg increse
Old Apr 3, 2007 | 09:23 PM
guroo987's Avatar
noticed a little mileage gain, nothin great, but it was there. truck is a lot quieter and i have the piece of mind knowing that my vp44 is getting lubricated!! also lubricating my holley at the same time. no reason not to run it, my .02
Old Apr 3, 2007 | 09:53 PM
Buckshotmckee's Avatar
Sma't Alec!
I've been running it for the past 1 1/2 years, in my 02, and now my 06. Here is what I've noticed. Smoother idle, less clatter/rattle (02) and improved fuel mileage! My main and only reason for running it is because of this new ULSD fuel and the lack of sulfur. I want the lubriticity it ads back into the fuel. Plus I get a little added smoke!
Old Apr 4, 2007 | 09:58 PM
dieseljunkie's Avatar
Never have run it, never really thought about running it. my problem is I never fill my tank up, unless I am towing my jeep a long distance. I usually put in about 40 bucks per stop, because my wallet can't take $100 at a time to fill up.
Scott
Old Apr 7, 2007 | 09:20 AM
Mopar1973Man's Avatar
Oh dang... The topic I love to argue on...
Well I got to admit I'm still using 2 cycle oil and I've seen awesome improvements. Quietier engine less knocking, improvement in fuel mileage, and I know every bit of my fuel system is lubricated.
Now as far quantity of oil to use. It simple to figure out. I've been using 1 oz for every 1 gallon of fuel. Or if you fill up from near empty then dump in a full quart (32 ounces).
As for my past discussions of this... I've had made of page full of information on the 2 cycle oil and other products. Never the less I did
finally **** off a company. Believe it or not I pissed off PowerService. So I hit a nerve with that one and ended up pulling my web page.
But my 2 cycle oil research still continues. I will be soon building a new personal web page with all new updated information.
Old Apr 7, 2007 | 07:05 PM
you got under ps's skin? What did they say?:pc:
