Pressure gauge.
Old Apr 26, 2012 | 09:35 PM
mossyoak54's Avatar
Default Pressure gauge.
Hey guys got my raptor pumped hooked up and going today. My question is where would I tie in my fuel pressure gauge with this set up?
Sent from the mans IPhone.
Old Apr 27, 2012 | 01:26 PM
GuyWithA24Valve's Avatar
I have mine hooked up at the bottom of the factory fuel bowl. I just used a tapped banjo bolt in the line that goes to the VP44
Old Apr 27, 2012 | 01:31 PM
RAW's Avatar
RAW
A tapped Banjo is a very common way to go. I have mine in the inlet to the VP44.
Old Apr 27, 2012 | 04:41 PM
mossyoak54's Avatar
So a tapped bango bolt just has a threaded fitting on the head correct?
Old Apr 27, 2012 | 04:46 PM
RAW's Avatar
RAW
You bet!
Old Apr 27, 2012 | 05:14 PM
This is only 1 way to do it -
Make sure you have a needle valve (almost completely closed) or pressure snubber in there to dampen the pressure spikes from the Injector Pump.
You can also get a T fitting. www.vulcanperformance.com has all kinds of fittings for installing FP guages.
VP-44 install -
huntman7
Sep 4, 2015 04:49 AM
SMatyac
Jan 24, 2015 10:55 AM
veggyoilkid
Nov 10, 2014 12:39 PM
wpg6.5
Oct 22, 2014 04:01 AM
scottxmorris
Oct 8, 2014 02:14 PM
