99-03 7.3L Performance Discussion of 99-03 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
TC Manual Lockup Not Working
Old Apr 23, 2012 | 12:41 PM
PSDGuy's Avatar
Default TC Manual Lockup Not Working
First off, my TCC is not locking at all. It seems to try to lock ever so slightly at part throttle (RPMs drop a bit, then return - either TCC trying to lock or compressor surge?).
It has tripped a code (O/D light blinking), but I was unable to check it and the last trip I made I didn't notice this behavior at all (didn't seem to attempt to lock).
I wired up a basic TC lockup switch (grounding the purple/yellow trans wire), but it has no effect. Measuring the voltage at the purple/yellow wire gives me .07 volts (with key on). Does this voltage seem appropriate for this PCM pin (I assumed it would be ~5v, but IDK).
Could it be that my TCC lockup selenoid needs replacement?
BTW, I was told the trans was "built" (I bought the truck a couple months ago) - it does shift nice and firm.
Cavnar
6.0L Performance
Apr 7, 2015 10:35 PM
somarillw
Dec 8, 2014 09:07 PM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
Oil Igniter
Nov 27, 2014 05:56 PM
