Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
Building an aux fuel tank
Old Apr 21, 2012 | 10:14 AM
Deezel Stink3r's Avatar
Default Building an aux fuel tank
I'm playing with the thought to build an aux fuel tank since I'm a member on DieselBombers.
In the past I have seen a couple of build-ups.
Since this site is mostly trucks they are mounted either inside the bed or undercarriage.
I have a '99 Jeep Cherokee´- Diesel of course and yes there is an aux fuel tank available. But a couple of things are a no-go.
First the price: 1300€ plus shipping from australia for only 13 gal (51 Liters) of diesel
is bit expensive, just 130$ per gal???
Secondly, that thing is hanging 4 inches below the unibody frame. Being hocked on a stump is just a question of time.
There is also a steel replacement tank made by Brown Davis- just seven gals more than the standard tank are not worth the price.
So after thinking a while I thought it would be ok to have a tank inside the trunk? Mounting jerry cans outside is prohibited by law in germany. Using jerry cans are giving only 5 gal per can extra.
So I was thinking to build an inside aux tank instead of using the spare tire.
this should be volume enough for an extra fuel supply of 20 gal and I could cover it with the stock tire carpet cover.
Which material should I use? Have in mind I want to be able to remove that tank with ease when not in use.
I have organized a fuel pick up and quick disconnect made for military 5gal jerry cans. So hooking it up should easy.
I would like to have a capacity of 20 gals. Any tips and hints?
How can I build a fuel level switch- telling me when it is time to switch over to the main tank.
Shall I use to independent filters? What else should I have in mind?
Any hint or picture is welcome! THX
Old Apr 21, 2012 | 11:13 AM
Whit's Avatar
Site Mascot
20 gallons is heavy. I don't think those securing rods will work. When building a fuel. Ell always weld inside seams first then install the top then seal weld al of the outside. Auto meter makes a good feel level Indicator and gauge. Make sure you do a top vent. I don't think a baffle will be necessary
Old Apr 21, 2012 | 11:20 AM
Whit, your external aux tank made me droolin' for ages.
I want one! Diesel is now 40 to 50 cents cheaper per gal in danmark than in germany. This would give me some extra range and saving a bit?
I collected already a couple of parts, like a to two way valve or a second fuel filter- just in case...
I just looked at the tire mount, and yes, it does look a bit flimsy! That thing is barely enough to hold a full size spare tire...
but 20 gal of fuel- I don't know?
Old May 20, 2012 | 09:56 PM
yakdaddy42's Avatar
get a fuel cell for a race car it is designed to be inside. I would not feel safe with a home made fuel tank inside the jeep with me.
Old May 21, 2012 | 05:46 AM
Thank you, that is a good input where to look at.
Luckily our safety inspection wants to see a certificate for the tank. It must be build by a certified welder and it must be pressure tested.
Old May 21, 2012 | 11:23 PM
deck60's Avatar
I have built several tanks over the years
steel is the easiest to do
have the main part bent in a U shape weld the ends in leave enough room to weld the outside also I would weld this with a mig wire feed do it in a single pass do not stop when finished the go over it with a tig then like wit says put the top on same thing wire feed then tig
when done pressure test it
Old May 24, 2012 | 02:39 PM
Thanks for the advice!
After having another look around the Cherokee I found the emtpy space behind the rear seats.
The picture below gave me some inspiration. What do you all think about it?
Since we go with the relative harmless diesel, I don't fear the fuel inside. I like the low gravity the use of useless space and the appearance.
Any concerns I can't see? Please let me know!
Old May 24, 2012 | 04:26 PM
Fuel inside the vehicle is legal in Germany? ....You arent going to vent the tank?
Is that your Cherokee? Doesnt look like mine looked.
Old May 25, 2012 | 04:35 AM
- its a Landrover Defender
Sure, you can mount your fuel tank whereever you want- as long as the fuel neck is located outside. The neck in the picture is illegal.
I have had the idea of using an external plane fuel tank from an Alpha Jet.
Our safety inspection officer went ballistic as I arrived with that "thing" at the safety inspection. 350L or 92gal+fuel tank weight is too much load in his opinion for a standard roof rack...
But the aerodynamic shape is priceless- you don't hear any noise nor existent drag due to its shape.( I'm tinkering with the idea to convert it into a roof storage container...)
Maybe I should go back to use two 5gal jerry cans?
Old May 25, 2012 | 11:43 AM
Thats looking like the best idea...or buy a truck and you can have a 100 gallong tank.
