Toyo 37's, gear upgrade?
Old Apr 20, 2012 | 09:42 PM
Lucky13SGT's Avatar
Default Toyo 37's, gear upgrade?
Owner of a cummins 5.9L powered 2006 Dodge Ram 2500 4X4, currently running 3:73's. I'm getting ready to install 37" toyo mt's and want to upgrade the gears, the truck is used 70% daily driver and 30% mix off road and towing.
Anyone have experience with this? Thinking either 4:10 or 4:56; feel like I'm undergearing a little with the 4:10 and overgearing a little with the 4:56...thoughts on how to proceed would be much appreciated.
Thanks,
Lucky
Old Apr 20, 2012 | 10:26 PM
Red_Rattler's Avatar
High Tech Redneck
410 will be plenty steep especially for a dd. I have 35's with 373 and it still drives and tows great. I like that it runs a few less r's goin down the road anyways
Old Apr 21, 2012 | 07:35 PM
Loghomeman's Avatar
If you go to a gear calculator and pull in the stock tire size and gear ratio and the new tire size it will tell you what size gears to go to keep as close with the stock ratio. my first lift on my 02 ford f250 with the 7.3L psd was a rubicon 6.5" lift and I went with 37" tires and changed my gears to 4:30. If you don`r regears at all you will notice a huge differance from stock tire size and gear ratio. You mpg and tranny will thank you. Gear Calculator: Use Our Gear Calculator for Proper Gear Ratios
Old Apr 23, 2012 | 05:13 PM
1AMatt's Avatar
Site Sponsor - 1aauto
I think you would be okay with 3.73's... 4.10's would prob be a little better though
Old May 20, 2012 | 10:46 AM
Karls03's Avatar
New tire divided by stock tire = rate of change.
Rate of change times OEM gear = new gear.
37/31.5=1.175
1.175 x 3.73=4.38275
4.11 or 4.56 would be your choices making your assumptions about gearing 100% correct. Given your driving needs, I would go 4.11.
Old May 22, 2012 | 11:59 AM
1AMatt's Avatar
There ya go. Gotta love math
Strictly Diesel
Strictly Diesel
Sep 17, 2015 05:11 PM
Jun 4, 2015 09:30 PM
D-350 dually
9
Feb 11, 2015 12:37 AM
rtbcoop
Nov 29, 2014 11:33 PM
Nov 6, 2014 08:10 AM
