Power
Old Apr 18, 2012 | 07:59 PM
wantpower's Avatar
Default Power
I've got a 935 Turbo 5 speed fuel pump turned up about 2 flats I pulled about 10000 pounds and pulled great on flat land couldn't even tell it was back there hit a small incline and it felt like 30000 is this normal or what can I do to help it thanks for any suggestion
Old Apr 18, 2012 | 08:46 PM
DieselCrawler's Avatar
is it bone stock? if so go to Hypermax and get their cowl induction kit, contact banks and get their upgraded downpipe for the factory turbo. that will help.
Old Apr 18, 2012 | 10:25 PM
wantpower's Avatar
Ok thanks ill check that out
That cowl reduction is it pretty much a cold air or what's the difference and I searched banks site for the down pipe
Old Apr 19, 2012 | 05:11 AM
like i said, call banks. it isnt not listed on the site. will cost around 100 bucks.
the cowl kit pulls air in from a High pressure area at the bottom of the windsheild. it does lower EGT by about 100 degrees when pulling hard
Old Apr 19, 2012 | 09:41 AM
wantpower's Avatar
Ok man just learning these older ones I had a 99little and sold it I'm starting to like this one better thanks for the info
Old Apr 19, 2012 | 11:10 AM
91dirtydiesel's Avatar
if your going to do it go all the way and take out the restricted elbow on the turbo outlet housing...or here is a guy that does it..... u can contact him...the part number for downpipe is part #52103 if your satisfied with just that
home made 093 upgrade - Ford Truck Enthusiasts Forums
Old Apr 20, 2012 | 08:16 AM
wantpower's Avatar
Ok done the cowl induction starting to Fab the down pipe truck has plenty of power smoke goes white to grey to black I'm thinking injectors or still running lean thanks for thethread on the down pipe very useful
Old Apr 20, 2012 | 10:49 PM
ALWAYSREADYROB's Avatar
Man I like that....Can I order one for my 94 IDI Turbo diesel.
Old Apr 20, 2012 | 11:42 PM
Yup
Old Apr 21, 2012 | 01:48 PM
wantpower's Avatar
How much is that down pipe
