I replaced glo plug timer. Is it sapposed to make loud clicks
Old Apr 18, 2012 | 03:55 PM
FORD-INTERNATIONAL MAN's Avatar
Default I replaced glo plug timer. Is it sapposed to make loud clicks
I replaced the moduale i just dont know if its sapposed to make loud clicks. Plus its not working. I replaced pretty much everything but still not working what do i do is there like a wire diagram i could get to se what i did wrong. Thank you for your time
Old Apr 18, 2012 | 04:19 PM
DieselCrawler's Avatar
loud fast clicks? means you have an open ciruct or bad glowplugs.
Old Apr 18, 2012 | 08:40 PM
But everything is brandy new. Glo plugs, the modualgel at the back of motor and the whole wiren harness.
Old Apr 19, 2012 | 09:38 PM
dieseleagle's Avatar
What brand of glow plugs did you use? Did you test them before?
Old Apr 20, 2012 | 10:42 AM
So i pulled a wirevoff a glo plug had my girlfriend turn yhe key while i had a test light in there and nothing lit up. So i gotta get a wire diagram from ford and trace all the wires
Old Apr 30, 2012 | 06:59 PM
stvktz's Avatar
DID YOU FIGURE IT OUT YET MINE DOES THE SAME
Old Apr 30, 2012 | 09:31 PM
I had an extra motor laying around and took it from that motor. Glo plugs work but my truck needs a rebuild because it wont start unless pluged in or if its hot
