Injector stuck!!
Old Apr 18, 2012 | 05:12 AM
MechanicalDiesel's Avatar
Default Injector stuck!!
So I went to take out my stock injectors and put in my new 5x.013s and I got one out but the rest wont budge. I tried the pipe washer and lug nut trick and it did nothing but strip my lug nut and stock injector. So what else can I do, make an injector puller? Is there some other trick to it? Whats the best penetrant to loosen it up? Im stuck please help
Old Apr 18, 2012 | 08:25 AM
RAW's Avatar
RAW
Injector Puller for 12V engines
Injector Change
Maybe there is something in there to help out
Old Apr 22, 2012 | 06:41 PM
Got the injectors out with the injector puller, and got the stuck one out with a little bit of wiggling
