What size injector?
Old Apr 15, 2012 | 05:29 PM
jake 94's Avatar
Default What size injector?
Hey guys I'm looking to go to a bigger injector. I was thinking either 200hp or 250 I'm not sure what to go with I daily my truck and rarely sees a trailer but sometimes I hall a 28foot enclosed trailer with the race car in it. Any help is appreciated thAnks guys
Old Apr 15, 2012 | 05:32 PM
Fire Power's Avatar
How does that turbo clean up your 150 sticks??
Old Apr 15, 2012 | 05:40 PM
jake 94's Avatar
Cleans up nice but it's laggy as hell. I'm thinking I don't have enof fuel to get that thing spinning. And I have edge jammers that are about done for
Old Apr 15, 2012 | 05:50 PM
Fire Power's Avatar
yeah then I would say 250 sticks would be just fine
Old Apr 15, 2012 | 06:52 PM
empty wallet's Avatar
will be smokey as hell with 250's
Old Apr 15, 2012 | 08:42 PM
jake 94's Avatar
What do you think I should run empty wallet? It's pretty smokey rite now with the 150s until the turbo lights. I was thinking 250s would be fine that's a lot of turbo? Let me no what you think thanks for the help
Old Apr 16, 2012 | 03:02 AM
It will probably be smokey no matter what... The lag probably has more to do with size of the exhaust wheel than it does being under fueled. You could run a 250 if you want but those laggy spots at low rpm's will be worse and you may not be able to clear them up... Or just barely but if you go with a 7x.012 with lift they will be cleaner than say my 7x.014 due to smaller orifice, both are 250's but different companies rate them differently, just make sure you know the size of what you get
Old Apr 17, 2012 | 12:27 AM
01quadcab's Avatar
I would say 200's max. lag is exhaust housing size in most cases. with a vp a 64 is harder to daily drive.
Old Apr 20, 2012 | 09:47 AM
jkidd's Avatar
we have 200, 220 and 250HP in stock.
CAM
Tunnel Ram plate
head work
will all make the truck more driveable.
Old Apr 20, 2012 | 10:39 AM
cummins270's Avatar
Yeah you might look into a cam. It helped my 62 spool better and less smoke.
