extreme egts
Old Apr 15, 2012 | 10:11 AM
lifted70's Avatar
Default extreme egts
I have a 04.5 5.9L with egts reaching 1500 degrees in the first 100 feet was wondering what intercooler water meth and anything else I should go with to cool it
Old Apr 15, 2012 | 10:22 AM
Fire Power's Avatar
Bigger turbo would fix it
Old Apr 15, 2012 | 10:25 AM
lifted70's Avatar
But with a larger turbo wouldn't you just be supplying more air to burn more efficient and not really cooling it?
Old Apr 15, 2012 | 10:30 AM
Fire Power's Avatar
If you have a stock turbo its choking the motor. Let it breath And burning it more efficiently will cool it
What for tuning are you using?
Old Apr 15, 2012 | 11:08 AM
lifted70's Avatar
Its got a raptor 150 lift pump feeding a motorsport diesel wicked cp3 and a edge attitude with hot unlock straight 4" exhaust and a cold air
Old Apr 15, 2012 | 03:38 PM
Fire Power's Avatar
Yeah you need a better turbo for sure
Old Apr 15, 2012 | 04:11 PM
lifted70's Avatar
Alright what do you recommend ?
Old Apr 17, 2012 | 10:08 PM
s10driver85's Avatar
you are running the hot unlock without a bigger turbo, or touching your injectors.... didnt you read the disclaimer you received?
Old Apr 18, 2012 | 09:23 PM
lifted70's Avatar
Talked to two different guys at edge and they said it would be alright to run and i can turn 1450 on the egts but still looking at a turbo injectors water meth and propane
Old Apr 19, 2012 | 07:14 PM
Ok, do your turbo. Then water meth.
