twin setups which one?
Old Apr 13, 2012 | 09:46 PM
cumminscwby's Avatar
Default twin setups which one?
Shop | Category: 2nd Gen Compounds | Product: Add a Turbo to your Phatshaft not sure if I like this setup or BD's twin setup better
Old Apr 13, 2012 | 11:00 PM
cummin_un_glued's Avatar
FormerVendor
i dont like the way the II kit is plumbed
Old Apr 14, 2012 | 04:31 PM
Yea, don't think I do either
Old Apr 15, 2012 | 03:00 PM
zach2's Avatar
I am wondering if I need more air. Do I have the fuel to run maybe a 62/65/12, or maybe my stock HX35 over something else? This is my daily driver.
Old Apr 15, 2012 | 06:26 PM
FormerVendor
you could do either one, you have enough fuel
Old Apr 16, 2012 | 03:41 PM
zach2's Avatar
Hey Buddy! Okay then, I'd like details as far as cost versus performance and which turbo to compound with my HX35. Consider installation difficulty as well.
Old Apr 16, 2012 | 07:34 PM
FormerVendor
a single is going to be the least expensive by far but there is no way to get compound performance from a single charger. usually doing compounds will cost close to double what a single will if your talking bolt on install. only turbo i would put under a hx35 would be a S471/88/1.32 or 1.10
Old Apr 16, 2012 | 08:17 PM
zach2's Avatar
Okay, thanks! If using my HX35 and plumbing the other turbo cost double over the single, I think I'll go for the single!
Old Apr 17, 2012 | 05:48 PM
FormerVendor
the primary turbo to go under your hx35 is less money then the single charger, but if you want a bolt on install then the piping kit is going to cost more then the turbo does. that being said if you can do your own fab work and do all of the plumbing your self then the compounds will be about the same as a single upgraded charger. then on the subject of single chargers they range greatly in cost pending who builds them and what exactly they are. single chargers can cost anywhere from $400 to $6000 just depends on whos and which one.
Old Apr 18, 2012 | 04:34 AM
zach2's Avatar
Okay. Thank you!
11B/11C
5.9L CR Performance
Jul 31, 2016 04:36 PM
heavyarms
13
Mar 20, 2016 03:24 PM
Blair@BD
BD-Power
Jul 17, 2015 12:44 PM
LadyyD
Chevy/GMC Duramax 2011 LML
10
Jun 1, 2015 05:30 PM
offroad00
24
Oct 23, 2014 03:28 PM
